chris79
Posted: Wed May 20, 2015 2:38 am Post subject: lower spring |
Now my Engine is ok, I would like only lower my car, but my budget is low, it's possible to install lower Spring with original suspensions ?
And rear it's easy to lower torsion bars by itself? Thanks _________________ Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro |
Posted: Wed May 20, 2015 5:35 am Post subject: |
Leave it alone, save your budget and do it once and correctly. _________________ Stefan
Posted: Wed May 20, 2015 3:40 pm Post subject: |
You can use lowering springs on fronts and use the factory adjustments on the rears to lower it...but...its difficult and brings problems.
Depending how low you want to go you have to do more or less work on the rears.
If you only want 10-15mm then its fairly easy but still brings problems.
If you want 25-30-50mm then you have more work and more problems.
The problems:
1. If you get a lot lower spring than you get not enough suspension travel, meaning bumps and holes go directly to the chassis and the car will be jumping around the road when you go over a bump.
2. if you lower it just a little, like 10-15mm max then its ok for the fronts but for the rears you have to adjust from the eccentric nuts. Thats also ok but the problem is you need to get a 4 wheel alignment after that.
3. if you lower it a lot then you have problem nr1 + you have to take off the whole torsion bar beam on the rears and adjust height...and then...guess what...you have to do a 4 wheel alignment.
New cars have no or very little wheel alignment systems...on the rears most cars have fixed geometry...but the 924 has adjustable...the problem is that you cant find any shop that knows how to and will align the wheels and in the end you get a car that jumps on the road, does not go straight and wears tires quite fast and not equally.
so...leave it alone i would also say. _________________ Supercharger and EFI kits
chris79
Posted: Wed May 20, 2015 4:50 pm Post subject: |
Ok I leave it alone, but I cant find any shop that knows how to and will align the wheels ?? It's possible ? _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Wed May 20, 2015 5:54 pm Post subject: |
| chris79 wrote: | | Ok I leave it alone, but I cant find any shop that knows how to and will align the wheels ?? It's possible ? |
You have to be sure that they know what they are doing.
It might be possible to find a shop that knows..but not likely. _________________ Supercharger and EFI kits
chris79
Posted: Wed May 20, 2015 6:30 pm Post subject: |
Porsche classic center can't made this work? _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Wed May 20, 2015 7:17 pm Post subject: |
| chris79 wrote: | | Porsche classic center can't made this work? |
They should surely be able to do it ! _________________ Supercharger and EFI kits
chris79
Posted: Wed May 20, 2015 9:47 pm Post subject: |
I have to consider if behove to modify asset of 924 na. _________________ Porsche 924 2.0 na 125hp (1979) euro
chris79
Posted: Wed Jun 10, 2015 10:50 pm Post subject: |
I decided to change asset of my car in this configuration:
Front:
-spacers 7mm
-lower Spring 20mm
-sport shock absorber
Rear:
-spacers 20mm
-torsion bar lowered 20mm
I think costs without work about 600 euro.
I would like Know if 4 weel alignement is strictly necessary after I lower torsion bar.
snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Thu Jun 11, 2015 4:10 am Post subject: |
if you don't do a 4 wheel adjustment you will most probably have camber issue with your wheels and kill the tires currently on the car.
normaly this means the inner portion of the tires will be wearing a lot faster than the exterior side and you will need to change tires more often.
this could also affect the handling of the car as you will have a smaller contact patch _________________ 1979 924 NA |
Harm
Posted: Thu Jun 11, 2015 4:39 am Post subject: Re: lower spring |
Flip through the Yellow Pages and find the oldest/best tyre shop in your town.
Place a call and inquire if they know how to work on a transaxle Porsche
Or have experience on the old beetles rear suspension.
Tell them you need an alignment and want to make an appointment.
Before you take the steps above, you make sure all bolts on front and rear suspension are serviceable
In my case the alignment took less then ~15 minutes and less then €50,
it was a major improvement.
We don't decide for you
All we have is advice.
Do your on math.
Kind regards,
Harm. _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
chris79
Posted: Thu Jun 11, 2015 6:18 am Post subject: |
Ok thanks, I think buy parts on ebay and then go to mechanic for installation, it's possible that total amount is about 1000 euro. _________________ Porsche 924 2.0 na 125hp (1979) euro
chris79
Posted: Fri Jun 12, 2015 4:49 am Post subject: |
And if change only shock absorber with koni without lower car and without stabilizer bar, the roll (eccessive in na not onroad but on track) can improve ? _________________ Porsche 924 2.0 na 125hp (1979) euro
snakoil
Posted: Fri Jun 12, 2015 9:37 pm Post subject: |
maybe you could save up by looking at the used market.
I see often sport springs or struts on rennlist and pelicanparts. _________________ 1979 924 NA |
chris79
Posted: Sat Jun 13, 2015 12:56 am Post subject: |
yes, but shock absorber used is a risk, this parts can be used for a lot of miles.
I would like buy new parts, I made this work one time, my car go for about 1000 km for year. _________________ Porsche 924 2.0 na 125hp (1979) euro
