Porver9two4
Joined: 22 Jan 2004 Posts: 104 Location: United Kingdom
Posted: Thu Jun 23, 2016 6:40 pm Post subject: Koni adjustables - worth it? |
Having recently recommissioned my trusty 924 my thoughts have turned to wickedness......
I have spotted these:- http://www.ebay.co.uk/itm/222155490972 (I am in the UK) which frankly look like a bargain with only 3 days left to run and am thinking about having a go. The same seller also has a 968 adjustable rear sway bar.
The question is how good (or otherwise) is the Koni adjustable suspension? Does anyone have experience? I am actually going to make my car too stiff and harsh, or will it really transform it as the seller suggests. I freely admit my current suspension has done some miles and isn't in the first flush of youth.... I was thinking about new front strut inserts anyway but it sure is tempting to try and bag this whole Koni set up for almost the same price as a pair of standard new strut inserts...
Any thoughts? |
Shurick
Joined: 15 May 2005 Posts: 524 Location: Russia, Moscow.
Posted: Thu Jun 23, 2016 7:35 pm Post subject: |
I currently have Koni shocks with 924S M030 springs/t-bars on my 931. It feels much stiffer than stock but handles much better. _________________ WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/ |
Posted: Thu Jun 23, 2016 7:50 pm Post subject: |
I need to find a pair of front adjustable inserts... _________________ Supercharger and EFI kits
Porver9two4
Posted: Thu Jun 23, 2016 11:05 pm Post subject: |
| Shurick wrote: | | I currently have Koni shocks with 924S M030 springs/t-bars on my 931. It feels much stiffer than stock but handles much better. |
Interesting. That is good to know. When you say 'much' stiffer, is it bone-jarring or just 'purposeful'? I track my car quite a lot, so don't mind a compromise of being a touch firm for road use.
| morghen wrote: | | I need to find a pair of front adjustable inserts... |
Do you rate the Koni ones as any good? or is there a recognised favourite amongst 924s? |
Kenodog
Posted: Thu Jun 23, 2016 11:13 pm Post subject: |
I would buy new if possible. You won't need the springs or housings despite how pimp they look, your car already has them. You just need the cartridges. Some people will point out they can be re-built if they blow and yes, the Konis are re-buildable, but it cost almost the same to send them for rebuilding as it does to just buy a new one so...just buy new and have the piece of mind that you get a warranty and many miles of worry free driving. If you want the cool yellow housings paint is cheap..
Leigh _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Shurick
Posted: Thu Jun 23, 2016 11:29 pm Post subject: |
| Porver9two4 wrote: | | When you say 'much' stiffer, is it bone-jarring or just 'purposeful'? I track my car quite a lot, so don't mind a compromise of being a touch firm for road use. |
For track car it is on soft side a bit, but on a bumps it feels a bit overdamped on rebound.
By the way, in yellow Koni shocks you can adjust only rebound, compression stiffens very little while you're tightening them. I believe it's a feature of valve design.
I adjusted mine in a middle position all round.
Here is a bit more info: http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=293 _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Fri Jun 24, 2016 12:01 am Post subject: |
I think Koni Sports are magical.
We've driven hard through the redwoods in NorCal a few times, and the way they handle uneven road surfaces, transitions, and hard braking with the suspension loaded is unreal.
I've had them on for years, and just last month we flogged over CA 29 on the way back from Sonoma, and they still feel the same. Fantastic dampers.
Gratuitous map:
Posted: Fri Jun 24, 2016 12:24 am Post subject: |
| Porver9two4 wrote: | | Do you rate the Koni ones as any good? or is there a recognised favourite amongst 924s? |
I would not know as i never had any of those. I'm after the adjustability for the fronts as i have fully adjustable suspension on the rears but only height adjustable on the fronts. _________________ Supercharger and EFI kits
Noahs944
Joined: 08 Dec 2015 Posts: 782 Location: Calgary, Alberta, Canada
Posted: Fri Jun 24, 2016 4:45 am Post subject: |
| I have owned new adjustable Koni fronts & New Sach front. Sach are good. Koni were great! |
Porver9two4
Posted: Fri Jun 24, 2016 8:35 pm Post subject: |
Thank you, some really useful replies. Sounds like they are worth a shot. Seller reckons they have done about 3000 miles, so nothing in the scheme of things. Wish me luck  |
Porver9two4
Posted: Mon Jun 27, 2016 7:28 pm Post subject: |
Update: wasn't able to win these - sold beyond my budget.
Hunt back on for viable suspension upgrades. |
Posted: Tue Jun 28, 2016 3:28 am Post subject: |
| Porver9two4 wrote: | Update: wasn't able to win these - sold beyond my budget.
Went for a silly price for used with no idea of age and mileage. 3000 miles with that rust on the rear shocks .... I don't think so. I bought Koni M030 adjustable coil overs front and rear with torsion bars for less than those.
Take a look at GAZ options, they do road, sport and race options from £400. If the car is a keeper, go new. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
BTRacing
