Gas Tank Connector Hose
MikeJinCO
PostPosted: Wed Jun 01, 2016 10:45 pm    Post subject: Gas Tank Connector Hose Reply with quote
Are the large rubber hose from the exterior filler neck to to the tank available for an early car?. I have gas smell in the interior and have traced it there.
Mike
'67 MG Midget Dp
michaelodonnell123
PostPosted: Thu Jun 02, 2016 1:00 am    Post subject: Reply with quote
I had a gas smell in my car as well. I had to drop the tank to change out all of the hoses and it fixed the problem. You might have to do the same.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
MikeJinCO
PostPosted: Thu Jun 02, 2016 7:08 am    Post subject: Reply with quote
Yes that is possible, but I could smell the gas right at the top large hose connection although is appears good. After 39 years anything is possible with those rubber hoses. Who did you get them from?
My gas smell is somewhat intermittent and not too bad. I think I can replace the large hose from the top so I'll do that and then work on trying to get a good airtite seal from the plastic cover to the interior.
Mike
'67 MG Midget Dp
michaelodonnell123
PostPosted: Sat Jun 04, 2016 4:14 am    Post subject: Reply with quote
I got mine from Pelican Parts. Give them a call. Also keep in mind that hoses go bad from the inside out. The walls gets thinned out and gasoline saturates them and reek of fuel. An airtight seal at the end of the hose will probably not help at all unfortunately since the problem is most like the hose itself. Let us know how it works out.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
