Wareagle32789
Joined: 23 Sep 2015 Posts: 39 Location: Winter Park, FL
Posted: Mon Dec 28, 2015 2:37 am Post subject: Spark plug wire order on distributor cap - mixed up! |
Ok, so I decided to change my distributor cap & rotor on my '80 924 NA.
I was careful to mark the wires and their positions prior to disconnecting the wires and removing the cap; however, I somehow mixed them up.
I went back through and tried connecting them in order to go around the cap 1-3-4-2, (clockwise) as marked on my valve cover, with one being the farthest from the front of the engine but when I tried starting it, no dice.
What's the best way to fix this without damaging my engine? |
Posted: Mon Dec 28, 2015 2:58 am Post subject: |
Cylinder 1 is the front. _________________ Toofah King Bad
Wareagle32789
Posted: Mon Dec 28, 2015 3:03 am Post subject: |
I got that, my problem is where on the distributor cap do I land the #1 wire?
when I tried to start it, there was a backfire and a puff of white smoke.
So, I think i need to pull off the spark plug wires from the distributor cap & start over with the connections.
I found some articles which mentioned finding TDC, but am not sure how to start, and couldn't find any marks on the distributor which indicate where to land the #1 cylinder wire. |
Wareagle32789
Posted: Mon Dec 28, 2015 3:20 am Post subject: Clarification |
On my original post, I think my question may have been unclear. I landed the wire from #1 cylinder (closest to the front of the car) to the position on the distributor cap at about 1:00 (as viewed from the front of the engine looking toward the fire wall, then went clockise from there.
Thanks |
Posted: Mon Dec 28, 2015 4:45 am Post subject: |
Back to basics. . .you need to set crank and cam to TDC per the manual, that will tell you where ignition wire #1 goes. _________________ Toofah King Bad
Posted: Mon Dec 28, 2015 4:54 am Post subject: |
With crank and cam at TDC, the rotor will point to the #1 terminal on the dizzy cap. _________________ erstwhile owner of just about every 924 variant ever made |
Wareagle32789
Posted: Mon Dec 28, 2015 5:26 am Post subject: |
| OK, I was afraid of that. Will I find the instructions for that in the Haynes' manual? |
jason c
Posted: Mon Dec 28, 2015 5:43 am Post subject: |
| Wareagle32789 wrote: | | OK, I was afraid of that. Will I find the instructions for that in the Haynes' manual? |
Yes. Its not difficult. Rotate the engine by hand, watch for the #1 intake valve to open & close then feel the #1 piston come to tdc (its highest point in the cylinder) with a screwdriver through the spark plug hole. You are then on tdc. Be careful & go slow so you don't bind on the screwdriver. |
Posted: Mon Dec 28, 2015 10:41 am Post subject: |
Or just use the TDC marker on the cam pulley. . .  _________________ Toofah King Bad
Wareagle32789
Posted: Mon Dec 28, 2015 12:03 pm Post subject: |
| Ok - is that the one on the timing belt? Not enthused about sticking things into the spark plug hole |
Posted: Mon Dec 28, 2015 1:04 pm Post subject: |
 _________________ White 87 924S "Ghost"
Wareagle32789
Posted: Tue Dec 29, 2015 6:04 am Post subject: |
| When I rotate the engine, does it turn clockwise? |
Posted: Tue Dec 29, 2015 8:28 am Post subject: |
From the front bumper looking back, yes, clockwise. _________________ Toofah King Bad
kcoyle
Wareagle32789
Posted: Tue Dec 29, 2015 10:51 pm Post subject: |
| Thank you! Pictures are really worth a thousand words! LOL |
