Wareagle32789
Joined: 23 Sep 2015 Posts: 39 Location: Winter Park, FL
Posted: Tue Dec 29, 2015 6:23 am Post subject: Parking brake cable - replacement options |
The previous owner of my '80 924 NA took out the windows, which allowed the interior to get pretty soaked. This caused major rusting at the hand brake and cable. I found a new handle, but can't get the nuts off of the old rusted cable end, so I think that the cable may also need to get replaced.
I'm having a hard time sourcing this cable, and wondered if there is some sort of VW/Audi equivalent part which may work for this...the only ones I can find are for 85 & up models, no dice for '80.
Any suggestions are appreciated |
Posted: Tue Dec 29, 2015 7:26 am Post subject: |
Recommend soaking the offending part in 50% acetone, 50% ATF. It will free up. When you reassemble, liberally apply anti seize. Easy peasy. _________________ Toofah King Bad
brian19600
Posted: Tue Dec 29, 2015 1:08 pm Post subject: |
4-lug and 5-lug cables are not the same...different lengths, different attachment, and different ends. If the OP's car has 5-lug, the ebay cable will work. _________________ erstwhile owner of just about every 924 variant ever made |
brian19600
Posted: Tue Dec 29, 2015 10:29 pm Post subject: |
Occasionally, there is someone on the board parting out a car. _________________ 78 924 |
Wareagle32789
Posted: Wed Dec 30, 2015 5:14 am Post subject: |
| I will try the acetone/ATF treatment & report back...thanks! |
