Patrick
Joined: 05 Dec 2007 Posts: 278 Location: Manila, PHILIPPINES
Posted: Mon Jan 04, 2016 6:06 pm Post subject: Meyle Oil Filter question |
Happy New Year All!
Its time to do an oil change. Considering whats available (and affordable) over here, i decided on a "Meyle".
Thing is, that what is available, is for a 70`s - 80`s VW Passat / Golf /Scirroco (Part # 100-115-0009). The specified Meyle filter for the 924 is # 100-115-0001.
The physical specs are identical, but i cant find anywhere (including their online catalog) info on the oil filter Relief valve (bypass valve) specs, as i wanted to compare both filters. I contacted Meyle but have not received a reply yet.
So my question is, does anyone have any idea if they would have a "close enough" bypass valve spec pressure, based on the part numbers? Thank You! patrick _________________ 1979 924 U.S. version
Single sidedraft Weber 40 |
gerben1986
Joined: 13 Mar 2008 Posts: 232 Location: The Netherlands
Posted: Mon Jan 04, 2016 7:45 pm Post subject: |
Beaware, because not only those specs, but also the height of the filter is important. Not all filters fit because of the location/available height. _________________ 911SC - 1980 |
Patrick
Posted: Mon Jan 04, 2016 10:08 pm Post subject: |
As i said, physical dimemsions are the same  _________________ 1979 924 U.S. version
Posted: Mon Jan 04, 2016 11:15 pm Post subject: |
if i'm not mistaken i'm using a Meyle fuel filter on my red 924...could be wrong tho. _________________ Supercharger and EFI kits
Patrick
Posted: Mon Jan 04, 2016 11:20 pm Post subject: |
Uhmm, i`m referring to the Oil filter  _________________ 1979 924 U.S. version
