Broken Hood Latch Cable
brooksdc
PostPosted: Sun Jan 17, 2016 6:40 am    Post subject: Broken Hood Latch Cable Reply with quote
Hoping somebody has a solution. I recently bought a 931 that had a broken hood latch cable. The seller simply never closed the hood completely, allowing him to open it. I know I should have put a rag or something between the latch and catch after I bought it, but the hood closed during transportation. Now, I don't have a way to re-open the hood.
I didn't really get any good hits when I searched the 924 board for repairing a broken hood latch cable. I came across these instructions on a 944 board, though:
1. Get the car on ramps
2. drop the belly pan
3. remove the electric fans (from the bottom - carefully, since there's no way to disconnect the battery first)
4. wedge a crowbar up into the bottom of the hood latch
5. destroy the lower part of the latch
Has anyone used or read of a better method?
Thanks in advance.
1977 924 MARTINI EDITION
1980 931 (two)
1986 944 NA white
1988 944 NA red
1988 944 LS1 hybrid
1986 951 black
1986 951 red
1988 951 Silver Rose
PostPosted: Sun Jan 17, 2016 7:22 am    Post subject: Reply with quote
Pretty similar. It's exactly the same as your 77 924 just with the airbox in the way.
So you should be able to actually access the catch from below if you pull the sway bar, radiator and airbox as well.
Not exactly easy, but if you take your time and work by feel.
PostPosted: Sun Jan 17, 2016 8:54 am    Post subject: Reply with quote
Assuming from your description the cable is broken at the latch, and not at the pull in the cockpit?
KDJones2000
PostPosted: Sun Jan 17, 2016 11:00 am    Post subject: Reply with quote
Ah, the memories....
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/437646-help-needed-picture-hood-release-stock-turbo.html?highlight=hood+latch
This works on the 944/951's, so it should work with your car as well.
Edit: Too bad the pictures are no longer working.
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
brooksdc
PostPosted: Mon Jan 18, 2016 11:47 am    Post subject: Reply with quote
KDJones - Thanks for the link. The method described there makes it sound like I can avoid destroying the hood latch.
Ideola - I am not sure if the cable simply slipped out of the latch or broke somewhere in the engine bay. The bulk of the cable is laying in the front floor board, though. Still, there may be some amount left that can be pulled from underneath the car.
I am taking it over to my mechanic tomorrow to put on his lift. I will report back.
1980 931 (two)
1986 944 NA white
1988 944 NA red
1988 944 LS1 hybrid
1986 951 black
1986 951 red
