joshPeck77
Posted: Thu Jan 14, 2016 2:25 pm Post subject: New here! |
Hello all, my name is josh and i have a 1977 924 in bright yellow. although it is not quite running yet i'm enjoying it so far.
i cant quite figure out why its not getting fuel to the distributor, i replaced the fuel pump because the old one was dead. i also replaced the fuel lines from the tank to the accumulators. itll chug to life on starter fluid but no gas makes it to the cylinders. help much appreciated. [/img] _________________ 1977 Porsche 924
2008 subaru outback "offroad" |
gerben1986
Joined: 13 Mar 2008 Posts: 232 Location: The Netherlands
Posted: Thu Jan 14, 2016 4:46 pm Post subject: |
Hi, welcome!
There is no fuel deleverid to the distributor?
Did you also replace the fuel filter? Maybe that's clogged also. _________________ 911SC - 1980 |
scm924s
Joined: 22 Oct 2010 Posts: 296 Location: Gloucester UK
Posted: Sat Jan 16, 2016 3:43 am Post subject: |
If it has been stood for a long time, suspect the fuel distributor central lift pin stuck. _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
Posted: Sat Jan 16, 2016 4:22 am Post subject: |
Yes, the WUR and Fuel distributor are both probably full of old fuel, etc.
Check out the How-to section for fuel distributor and WUR (Warm-up Regulator) cleaning information.
DIY Fuel distributor rebuilds are pretty hit/miss, so you can send it off to be professionally rebuilt.
Once you have fuel at the injectors, then you'll need to verify your injectors are all flowing properly. _________________ Stefan
Power Tryp
Joined: 16 Apr 2009 Posts: 435 Location: Calgary, Alberta
Posted: Sat Jan 16, 2016 6:33 am Post subject: |
You may not even need to rebuild the fuel dizzy. Just pull the smaller distributor (square puck with all the fuel lines) off the metering body and be very careful not to let the pin in the middle fall out if it isn't gummed up and stuck in there. _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
