Is my NA running too cool?
XLR8
PostPosted: Mon Apr 04, 2016 4:23 pm    Post subject: Is my NA running too cool? Reply with quote
Hi all,
My 924 NA seems to run very cool all the time.
During normal driving (admittedly usually higher speed as I leave rurally) she gets to the top of the "cold" area on the temp gauge.
Pootling around the town, only to the first line on the guage (is that 1/4 way?).
All with ambient temps up to 30 degC (86 degF).
Am I just lucky? Or is this not usual?
Is my gauge perhaps reading incorrectly (though when I stop the car she never seems "hot")?
Also, the thermofan switch will often stay on for up to 10 minutes after the car has stopped. I fear it may be faulty and switching at a very low temperature.
Any advice appreciated.
'81 Porsche 924 NA
'89 Eunos Roadster NA6
'06 Landcruiser HDJ100
PostPosted: Mon Apr 04, 2016 11:51 pm    Post subject: Reply with quote
More or less what mine does, due to cold thermostat and fan switch (they come in different temps).
Plus, as you noted, the gauges can be less than 100% accurate, usually due to grounding problems. If you're concerned, get a laser pyrometer and check the water flanges and cylinder head.
XLR8
PostPosted: Tue Apr 05, 2016 6:17 am    Post subject: Reply with quote
Thanks Rasta, makes me feel better. I'll ensure the thermostat and thermofan switch are similar in temp some time on the future. I will have the dash out soon and there's quite possibly a ground issue, so will let you know how that goes.
'81 Porsche 924 NA
PostPosted: Tue Apr 05, 2016 7:10 am    Post subject: Reply with quote
Ground between engine and body can also impact oil pressure and water temp gauges...
