RobertN
Joined: 19 Apr 2015 Posts: 142 Location: Lisburn Co Antrim
Posted: Tue May 17, 2016 6:27 am Post subject: Cold idle problem |
Hi Guys, got the emissions done 1.0 and passed the MOT. Good for another year
Next morning she fired up but was very lumpy and struggled to idle at 950 until almost running temp. I had to hold the accelerator pedal slightly to keep her from stalling.
Could she be running too lean or too rich?? How do I maintain good cold idle if my hot idle is perfect!
Thanks. _________________ Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders. |
Posted: Tue May 17, 2016 7:56 am Post subject: |
it could be a little more rich.
I think the maximum for MOT is 2 _________________ Porsche 924 1984 (UK import) NA
Posted: Tue May 17, 2016 9:14 am Post subject: Re: Cold idle problem |
| RobertN wrote: | | Could she be running too lean or too rich?? How do I maintain good cold idle if my hot idle is perfect |
Not answerable until: a) intake has been tested for leaks on a smoke machine, and; b) fuel pressures have been verified with a proper tester. _________________ Toofah King Bad
RobertN
Posted: Wed May 18, 2016 2:15 am Post subject: |
Thanks guys. Emission pass here is 4.5 CO and 1250 HC.
Yes need to invest on a cis tester.
Btw the idle screw is 6 full turns out from its seating point?? Too much?? Idle is around 950 hot. _________________ Robert.
scm924s
Joined: 22 Oct 2010 Posts: 296 Location: Gloucester UK
Posted: Wed May 18, 2016 5:30 am Post subject: |
Your emissions are too low IMHO, these things are best around 2 to 3%, I normally aim for 2.5, but it does vary car to car. _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
RobertN
Posted: Wed May 18, 2016 6:07 am Post subject: |
| scm924s wrote: | | Your emissions are too low IMHO, these things are best around 2 to 3%, I normally aim for 2.5, but it does vary car to car. |
You think I have messed the cold idle as a result of low co adjustment? She was always good before!! When warm she runs really well and starts perfectly. _________________ Robert.
scm924s
Posted: Wed May 18, 2016 6:25 pm Post subject: |
Poor cold start can arise from a number of problems, CSV or WUR not operating correctly, but my first thoughts in this case would be too lean a mix at idle _________________ 1984 n/a Ruby Red Metallic
RobertN
Posted: Wed May 18, 2016 7:11 pm Post subject: |
csv okay. How do adjust the mixture from lean to rich? Clockwise turn?? _________________ Robert.
scm924s
Posted: Wed May 18, 2016 10:23 pm Post subject: |
Yes, but VERY small adjustment has a large effect! Ideally a CO2 meter should be used. _________________ 1984 n/a Ruby Red Metallic
RobertN
Posted: Wed May 18, 2016 10:26 pm Post subject: |
Cheers. I have a Gunson gas tester which I use for the mot tests.
Thanks again. _________________ Robert.
