canyonblaster
Joined: 20 Aug 2012 Posts: 391 Location: Denver, CO, USA
Posted: Mon Jun 20, 2016 4:39 am Post subject: 1981 931, all of a sudden car seems like it is running rough |
feels like it is running at redline when it is is only at 4K RPM? Argh...
Any ideas? Thx!
BTW, I wonder if the ambient heat is responsible. 95 F here and high altitude (Denver CO). _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
Past P cars, 1985 944, 1987 951, 1990 911 C4, 2002 Boxster S, 2005 996 GT3, 2013 911 C2S
Daily Driver P cars: 2008 Cayenne GTS, 2013 Cayenne GTS |
Posted: Mon Jun 20, 2016 5:19 am Post subject: |
boost leak?
If its an S2, the TB oring has softened up and got spewed out?
That happend to mine. _________________ Supercharger and EFI kits
Posted: Mon Jun 20, 2016 6:58 am Post subject: |
Fuel blockage/leaning out _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon Jun 20, 2016 1:46 pm Post subject: |
Immediate wideband, please. _________________ Toofah King Bad
canyonblaster
Posted: Tue Jun 21, 2016 3:12 am Post subject: |
| morghen wrote: | boost leak?
That happend to mine. |
Please clarify what this is? Thanks! _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
canyonblaster
Posted: Tue Jun 21, 2016 3:13 am Post subject: |
| Rasta Monsta wrote: | | Immediate wideband, please. |
Rasta, can my shop likely test that? _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
canyonblaster
Posted: Tue Jun 21, 2016 3:14 am Post subject: |
| Carrera RSR wrote: | | Fuel blockage/leaning out |
Gas tank, all fuel pumps and filters are new,recent. When sitting idling, engine revs fine. _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
Posted: Tue Jun 21, 2016 3:48 am Post subject: |
| canyonblaster wrote: | | Rasta, can my shop likely test that? |
I suppose, but it would still require installing a pre-cat wide band O2 sensor, and testing under load. Adding an AFR gauge is a better long term solution. _________________ Toofah King Bad
Posted: Tue Jun 21, 2016 7:15 am Post subject: |
| canyonblaster wrote: | | Carrera RSR wrote: | | Fuel blockage/leaning out |
Gas tank, all fuel pumps and filters are new,recent. When sitting idling, engine revs fine. |
It will, the engine is not under load. Either air is getting in causing it to lean or fuel is being restricted and going lean
As rasta says, an AFR gauge will tell you if it's lean or rich under load. Best rested on rolling road.
Assume boost is OK too? If it's over boosting then the overboost switch kicks in by cutting the fuel pump. Again leaning it out. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
canyonblaster
Posted: Tue Jun 21, 2016 8:11 am Post subject: |
Thanks guys. What is the TB O Ring? _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
Kenodog
Posted: Tue Jun 21, 2016 10:51 am Post subject: |
The TB O-ring is the throttle body o-ring. On S2 cars there is a rubber o-ring that theoretically seals between the throttle body itself and the charge tube. All kinds of nastiness can happen to them over the years. Replacement Viton ring is about $6 and is another check mark on the list of cheap and easy things to do to have a reliable 931.
Me _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
canyonblaster
Posted: Thu Jun 23, 2016 6:58 am Post subject: |
I suspected it was heat soak or vapor lock. Weather is nice and cool today, 80 F. I vented the gas gap, added some fuel (it wasn't empty but was low), and the car drove like a top today! Yahoo! _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
