Schwami
Joined: 11 Apr 2016 Posts: 85 Location: Wisconsin Green Bay
Posted: Mon Jun 13, 2016 6:12 am Post subject: Trans axel bushings installation question. |
In which orientation do the 2 transaxle bushings go in shifting coupler?
Mine have disintegrated and I know of no reference to the direction to replace them.
79 n/a 5 speed
Thanks _________________ 1979 924 Diamant Zweischicht.
Serial # 9249201031
XG 309 543 engine code.
2012 Golf Sportwagon TDI |
Posted: Tue Jun 14, 2016 12:18 am Post subject: |
The "ears" go on the inside. You push them in from the inside. There's only one way they can go in. _________________ erstwhile owner of just about every 924 variant ever made |
Schwami
Posted: Thu Jun 16, 2016 10:11 pm Post subject: |
Thanks Dan!
I got them together and switched the ratchet lever to install! Few days and I'll be back to smiling. Except for that loud fuel pump. Any word on the compression fittings? My 79 doesn't have banjo bolt....
Also any more info on the 9/24 gig? _________________ 1979 924 Diamant Zweischicht.
Serial # 9249201031
Posted: Fri Jun 17, 2016 2:00 am Post subject: |
| Schwami wrote: | Thanks Dan!
Also any more info on the 9/24 gig? |
Sorry about the tardy reply on the compression fitting. Pretty sure I have a Walbro fitting kit that will give you what you need. I've been traveling insanely for work the past two weeks, and will be until next Sunday. Have only had 36 hour turn arounds over the weekend, so not much time to chase stuff down!
RE: the 9/24 event, I'll get some posts up here and on the other forums in addition to the Chicagoland FB group. The event is definitely on, and we're set up to accommodate anyone who wants to camp out. More details to follow, hopefully within the next week or so. _________________ erstwhile owner of just about every 924 variant ever made |
