Steering Rack Ground Strap
PostPosted: Mon May 30, 2016 8:18 am    Post subject: Steering Rack Ground Strap Reply with quote
Trying to figure out the above.
If there's anyone who could conveniently snap a pic, I'd be grateful.
brian19600
PostPosted: Mon May 30, 2016 10:50 pm    Post subject: Reply with quote
I just went out, climbed under the car and looked and I didn't see any ground strap. Do you have the PET page that would show it?
Kenodog
PostPosted: Tue May 31, 2016 3:33 am    Post subject: Reply with quote
Never seen one. The assembly is bolted to the cross member which is bolted to the chassis. Wouldnt really need a ground.....
Me.....Leigh
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
PostPosted: Tue May 31, 2016 3:56 am    Post subject: Reply with quote
I have seen ground straps on some cars from the block to the cross member. From memory, I seem to recall it going from one of the bolts by the A/C / Alternator bracket, and then grounding to the upper LHS bold where the steering rack mounts to the cross member.
PostPosted: Tue May 31, 2016 12:18 pm    Post subject: Reply with quote
Thanks for the replies. Fwiw, my car did have a ground strap from an oil pan bolt to the x member.
hdrider19
PostPosted: Sun Jun 12, 2016 5:29 am    Post subject: Reply with quote
About to drop engine out of my 87 24S. There is a small ground wire on the clamp bolt for the pressure hose straight down from steering shaft. It runs over the back side of pressure hose and down to cross member about 3 inches to the left of lower drivers side rack mount bolt. It is held to x member with a Phillips screw. Still don't have photobucket set up. Sorry. Hope this helps. Paul
hdrider19
PostPosted: Mon Jun 13, 2016 11:00 am    Post subject: Reply with quote
I just checked my 84 944 parts car. It also has this ground wire in the same location I described above.
hdrider19
PostPosted: Mon Aug 01, 2016 12:01 pm    Post subject: Reply with quote
Sorry it took so long to post this. Had to give up on photobucket. I hope it helps.
87 924S
