Posted: Sat Aug 06, 2016 11:08 am Post subject: 931 injector thread pitch? |
Does any one know what the thread pitch is on the 931 injector, where it threads into the brass portion of the injector bung? The injectors themselves are ~9mm at the barrel, and the thread is very fine. I've never heard of an M9... _________________ erstwhile owner of just about every 924 variant ever made |
Mike9311
Posted: Sat Aug 06, 2016 11:34 am Post subject: Re: 931 injector thread pitch? |
| ideola wrote: | | Does any one know what the thread pitch is on the 931 injector, where it threads into the brass portion of the injector bung? The injectors themselves are ~9mm at the barrel, and the thread is very fine. I've never heard of an M9... |
I have thread gauges at work and I will check tomorrow _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
Mike9311
Posted: Sun Aug 07, 2016 1:34 am Post subject: Re: 931 injector thread pitch? |
| Mike9311 wrote: | | ideola wrote: | | Does any one know what the thread pitch is on the 931 injector, where it threads into the brass portion of the injector bung? The injectors themselves are ~9mm at the barrel, and the thread is very fine. I've never heard of an M9... |
I have thread gauges at work and I will check tomorrow |
0.75 as far as I can tell (that is fine indeed on the injector)
I will clean the injector up a bit and look under a scope to confirm but I am sure already
I would say M10 x 0.75 which has the major dia at 9.978/0.392. I measure 0.389" _________________ 1980 931 since 1989
Mike9311
Posted: Sun Aug 07, 2016 1:50 am Post subject: |
Looked like it too under the scope. 0.7 and 0.8 don't work and are not standard anyway. Standard 0.5, which is even finer, is super far off _________________ 1980 931 since 1989
Posted: Sun Aug 07, 2016 4:13 am Post subject: |
But I think it's M9, not M10, right? I'm measuring the barrel at 9mm. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sun Aug 07, 2016 5:06 am Post subject: |
Minor diamiter of m10x0.075 threaded hole is 9.378-max 9.188-min.
So if your measuring that hole somewhere between 9.188 and 9.378 then it is correct for a m10x0.075
M9x0.75 is 8.188 to 8.378 _________________ 80 Turbo - Slightly Modified |
Mike9311
Posted: Sun Aug 07, 2016 5:40 am Post subject: |
I have the barrel measured at near 9.1 for my example. The minor would be larger than the 9.1 so its still more likely at 10 x 0.75
Threads play tricks with the mind
I only have 10 x 1.5 bolts here and a 10 x 1.0 tap. Each measure at the same dia as the injector for 10mm _________________ 1980 931 since 1989
Mike9311
Posted: Sun Aug 07, 2016 5:50 am Post subject: |
You could always order a nut to test _________________ 1980 931 since 1989
