Posted: Wed Aug 03, 2016 8:37 am Post subject: New products added to Ideola's Garage website |
I've added a bunch of new products to the site
Ideola's Adjustable Cam Gear
Suitable for all 924/931.
$285 click to purchase
Brass Oiler Elbow
Replace the crack-prone OEM plastic elbow for the last time! Hat tip to 924board member RC.
$45 click to purchase
Center Dual Gauge Pod
Black only. Suitable for all 1977-82 924/931 2.0L, 1982-85.5 944, and 1986-88 924S. Extremely limited supplies! Straight (4 remaining) or Angled (temporarily sold out) binnacles. Hat tip to 924board member 924-76
Dimple Magnetic Drain Plug
For 924/931 2.0L.
$35 click to purchase
ARP Main Stud Kit
For 924/931 2.0L.
$149 click to purchase
ARP Flywheel Bolts
For 924/931 2.0L.
$59 click to purchase
Head Accessory Gasket Set
Don't need a complete head gasket kit? Several of the head accessory gaskets are NLA individually. We solved that by having them scanned in high resolution and CNC-cut out of high quality gasket material. Includes the thermostat housing gasket, the head breather gasket, the ovoid throttle body gasket (NA and S1 931 only), the distributor housing gasket, and the distributor-to-housing gasket.
$26 click to purchase
G31/G16 Mid-Housing Gasket
G16 and G31 rebuild kits are no longer available from Porsche. We are still working on identifying alternative sources for the various radial seals, o-rings, synchros, etc. In the meantime, we have commissioned a high resolution scan and CNC-cut paper gasket for the NLA gasket (477.301.191.A) that goes between the front and mid housing. Available ONLY from Ideola's Garage!
$16 click to purchase
And a special tip of the hat to lildude4life for the excellent engineering assistance on the gaskets and a few other goodies that are in the works!!! _________________ erstwhile owner of just about every 924 variant ever made
Posted: Wed Aug 03, 2016 8:44 am Post subject: Re: New products added to Ideola's Garage website |
| ideola wrote: | Head Accessory Gasket Set
Don't need a complete head gasket kit? Several of the head accessory gaskets are NLA individually. We solved that by having them scanned in high resolution and laser cut out of high quality gasket material. Includes the thermostat housing gasket, the head breather gasket, the ovoid throttle body gasket (NA and S1 931 only), the distributor housing gasket, and the distributor-to-housing gasket.
$26 |
Nice. . . _________________ Toofah King Bad
Posted: Wed Aug 03, 2016 8:57 am Post subject: Re: New products added to Ideola's Garage website |
| Rasta Monsta wrote: | | ideola wrote: | Head Accessory Gasket Set
$26 |
Nice. . . |
More of these are on the way. We've scanned the entire lot of gaskets for the block, head, and intake, so we have the ability to produce anything from the set now. We started with the items that seemed to be hardest to find individually. _________________ erstwhile owner of just about every 924 variant ever made |
Mike9311
Posted: Wed Aug 03, 2016 11:41 am Post subject: |
Thanks for the main stud kit! Need them for one of my spare blocks for sure _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
lildude4life
Posted: Wed Aug 03, 2016 3:08 pm Post subject: Re: New products added to Ideola's Garage website |
| ideola wrote: | | Rasta Monsta wrote: | | ideola wrote: | Head Accessory Gasket Set
$26 |
Nice. . . |
More of these are on the way. We've scanned the entire lot of gaskets for the block, head, and intake, so we have the ability to produce anything from the set now. We started with the items that seemed to be hardest to find individually. |
Only issue I have at the moment with gaskets is how to cut any of them that are either fully metal, or have a metal layer sandwiched between two gasket layers. I currently don't have any way of cutting them available to me at the moment but Dan said that most of the exhaust related ones are still available and they are the main ones with a metal layer (manifold to turbo, waste-gate, etc).
Sorry to bust your bubble, but they weren't laser cut. They were done on a ZUND CNC router.  _________________ "931 EFR" 81 931 S2 w/ EFR 6258 turbo, EFI, Haltech Elite ECU, 240whp |
Posted: Wed Aug 03, 2016 11:29 pm Post subject: Re: New products added to Ideola's Garage website |
| lildude4life wrote: | | ZUND CNC router |
Fixed! _________________ erstwhile owner of just about every 924 variant ever made |
Power Tryp
Joined: 16 Apr 2009 Posts: 435 Location: Calgary, Alberta
Posted: Thu Aug 04, 2016 2:01 pm Post subject: |
I'm going to need one of those mid housing gaskets soonish. I was going to use Loctite 574 but i'd feel better with a real deal gasket. _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
Mike9311
Posted: Thu Aug 04, 2016 11:09 pm Post subject: |
Just ordered...
Will be ordering a ARP main stud kit or two very soon _________________ 1980 931 since 1989
Posted: Fri Aug 05, 2016 2:40 am Post subject: |
Thanks for the order Mike! Angled units temporarily sold out... _________________ erstwhile owner of just about every 924 variant ever made |
Mike9311
Posted: Fri Aug 05, 2016 3:02 am Post subject: |
| ideola wrote: | | Thanks for the order Mike! Angled units temporarily sold out... |
I can change it for a straight? _________________ 1980 931 since 1989
Posted: Fri Aug 05, 2016 3:39 am Post subject: |
No need, you got the last angled one! _________________ erstwhile owner of just about every 924 variant ever made |
Mike9311
Posted: Fri Aug 05, 2016 4:39 am Post subject: |
| ideola wrote: | | No need, you got the last angled one! |
Awesome, thanks! _________________ 1980 931 since 1989
Mike9311
Posted: Sat Aug 06, 2016 4:33 am Post subject: |
fastest shipper ever this side of the Pecos river....thank you
I am already holding it in my hand  _________________ 1980 931 since 1989
Posted: Sat Aug 06, 2016 5:37 am Post subject: |
I'm working with Claude for another run of the dual gauge pods. No ETA yet, but we do expect to get some more later this summer / fall. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat Aug 06, 2016 6:10 am Post subject: |
| Mike9311 wrote: | fastest shipper ever this side of the Pecos river....thank you
I am already holding it in my hand  |
My intake came fast too.. _________________ 80 Turbo - Slightly Modified |
