Rear fender flares
Han Solo
PostPosted: Wed Nov 16, 2016 2:53 am    Post subject: Rear fender flares Reply with quote
Started in on the rear flares last night. Hung the flare with painters tape for exact positioning. Then outlined with a sharpie. I'm going to cut the wheel well 1" back from the OEM opening. There's an inside layer that will probably have to be re-joined to exterior skin with welds. I think I'm going to use a cut-off wheel instead of body saw. Note that the passenger side has some poorly repaired dents that will be mostly covered by the flare. There's one area by the passenger door where I'll probably encounter body filler.
-----HAIRY ANT NEST RACING-----
Collecting, racing and restoring Porsches for fun and negative cash flow.
-----Epic 914 race car build----- http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/767721-yet-another-rescue-porsche.html
PostPosted: Wed Nov 16, 2016 3:39 am    Post subject: Reply with quote
Cool!
Fyi, there is a sub forum here dedicated to body projects.
Han Solo
PostPosted: Wed Nov 16, 2016 3:47 am    Post subject: Reply with quote
Rasta Monsta wrote:
Cool!
Thanks. I'll take a look and see if anyone else has put those on.
joecitizennn
PostPosted: Wed Nov 16, 2016 4:43 am    Post subject: Reply with quote
I would cut a little higher than 1" at the top unless you are planning on rolling the remaining steel up and out of the way. You will need more room for suspension travel.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
Han Solo
PostPosted: Wed Nov 16, 2016 5:04 am    Post subject: Reply with quote
Yeah, I'm looking at that. I'll be running 275 x 35 x 15 Hoosiers which are considerably smaller O.D. than OEM so clearance should be fine. I've lowered the rear control arms and don't plan on getting any lower unless corner balance is not good. That would entail re-indexing the torsion bars and we all know how much fun that can be
Also, I just read through Hugo Jacobs DYI and I'm not sure I'll do that method. He basically created an inner liner using the flared material. I can see a need for that on a street or track car but autocross is different. Much shorter distances and duration. I like this method though...
https://www.youtube.com/watch?v=yGrGvuvxq-o
Except for the riv-nuts. I'll fix the flares with pop rivets or sheet metal screws and then fiberglass the flare to the car (maybe with some assist from adhesive). Drill out the rivets or extract the screws, body fill and finish.
PostPosted: Wed Nov 16, 2016 7:13 am    Post subject: Reply with quote
Cut more, just to be sure.
I did not weld the panels, i treated for rust protection and then used polyurethane glue to fill the gap. No rust and no leaks in...must be over 10 years now.
joecitizennn
PostPosted: Wed Nov 16, 2016 7:20 am    Post subject: Reply with quote
The cutting of the wheel arch is related to wheel travel. You do not need to remove metal in front of or behind the tire, just above it where it will travel. 1" is not enough. 3" and a little forward for the swing of trailing arm.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
PostPosted: Wed Nov 16, 2016 8:36 am    Post subject: Reply with quote
http://www.iribbit.net/i/_files/924cgt_rear_flares_by_hugo_jacobs.pdf
Han Solo
PostPosted: Thu Nov 17, 2016 12:16 am    Post subject: Reply with quote
Agreed. I compressed the rear suspension, measured to the 1" cut on the sides 16.5" and then made an arch over the top to match. Should be plenty of room for travel. Note that your picture has a 225 x 50 x 16 tires and I'll be running 275 x 35 x 15. That's a 26" tall compared to 22.5". I think I'll be fine unless I move into a 16" wheel which is unlikely.
19marty73
PostPosted: Thu Nov 24, 2016 2:33 am    Post subject: Reply with quote
Brave cuts my friend. I think this rear arch modification stops a lot of people carrying out a 924 GT conversion. I have been pondering this exact modification since 2001! looking forward to see the progress.
Han Solo
PostPosted: Thu Nov 24, 2016 2:55 am    Post subject: Reply with quote
Thanks. It certainly steels one's courage when you're cutting into a race car project that will never be a restoration. Follow my progress on this thread my friend...
http://www.924board.org/viewtopic.php?t=42067&start=30
