FUEL FILLER PLUMBING - DETAIL PICS NEEDED
PostPosted: Sun Jan 01, 2017 4:21 am    Post subject: FUEL FILLER PLUMBING - DETAIL PICS NEEDED Reply with quote
I'm working on refreshing the gaggle of hoses around the filler pipe, and have lost track of how the cloth vent line is routed from the filler pipe to the nylon pipe that goes to the engine compartment.
Any detail pictures of this area, from above or from below with the tank removed would be greatly appreciated.
Thanks,
rasta
PostPosted: Sun Jan 01, 2017 6:00 am    Post subject: Reply with quote
Which car? I think the 924S is slightly different than the 2.0L cars...the cover is definitely different...
PostPosted: Sun Jan 01, 2017 6:11 am    Post subject: Reply with quote
Not concerned about the cover. . .I reckon I can figure out how that goes on.
My recollection was that the early 944 and 924S carried forward the same setup as the toofah, but maybe that's not correct.
Han Solo
PostPosted: Tue Jan 03, 2017 11:37 am    Post subject: Reply with quote
The 924S is the same as S2 931, that I do know as I've been into the fill neck area of both. The smaller vapor hose that's goes up into the B pillar is connected to the plastic vapor hose that runs all with the fuel lines to the engine compartment. The larger hose in that area connects to the vapor extraction on the tank with the odd liquid trap device.
-----HAIRY ANT NEST RACING-----
Collecting, racing and restoring Porsches for fun and negative cash flow.
-----Epic 914 race car build----- http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/767721-yet-another-rescue-porsche.html
PostPosted: Tue Jan 03, 2017 1:10 pm    Post subject: Reply with quote
Thanks for the reply. I bought a replacement for the cloth covered line that goes from the second check valve to the hard line, but pulled it apart so long ago I wanted to verify routing.
That's why I was hoping for photos.
Han Solo
PostPosted: Thu Jan 05, 2017 3:18 am    Post subject: Reply with quote
I have some on my build thread but here there are again. You can see where the two vapor lines from the tank have been disconnected from the fill neck in the first photo. The second shows the smaller line with the check valves. That connects to the plastic hard line going up front.
PostPosted: Thu Jan 05, 2017 3:42 am    Post subject: Reply with quote
excellent, thought I remembered that metal clip. what was it attached to?
Han Solo
PostPosted: Thu Jan 05, 2017 3:47 am    Post subject: Reply with quote
IIRC that was just clipped to the edge of the fill tube opening in the trunk pan. Just a retaining clip to keep the hose from getting pulled.
PostPosted: Thu Jan 05, 2017 10:00 am    Post subject: Reply with quote
still got it apart? is there a witness mark from the clip?
Han Solo
PostPosted: Thu Jan 05, 2017 10:21 am    Post subject: Reply with quote
I think you can see the spot in the second photo Rasta. It's the slightly clean area on the edge of the opening. You know that cover is sealed with tar and that's were the clip was under.
