Kenodog
Posted: Thu Jul 20, 2017 2:05 pm Post subject: Disc wear limit |
I tried to look up the minimum rear disc thickness in Haynes but it is not listed. Anyone remember off hand what it is ...?
tia,
Leigh _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Rhubie
Posted: Thu Jul 20, 2017 3:27 pm Post subject: |
I couldn't find it either(though it is 12am my time at the moment)
Honestly, if you have to question and it makes you uncomfortable just replace it. Easy fix in my mine _________________ 1980 Porsche 924 Weissach Commemorative Edition |
SlayerSST
Posted: Thu Jul 20, 2017 5:51 pm Post subject: |
Front
Rear
These specs are for CENTRIC rotors which should be similar to other brands.
Info is good for 924 cars that came with 5 lug suspension. |
TJC
Joined: 04 Apr 2010 Posts: 828 Location: Northwestern-ish Arizona, USA
Posted: Fri Jul 21, 2017 1:06 am Post subject: |
That spec is also usually cast or engraved on the rotor itself. _________________ '95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com |
Kenodog
Posted: Fri Jul 21, 2017 7:55 am Post subject: |
Thanks guys. Yes, I knew they were usually stamped on the side but I could not find it on these particular rotors. I only asked because I got a set of already turned rotors in a parts lot for a guy that is a VW / Audi mechanic. He was a very, very particular type of guy so i figured he would have measured them and turned them at work as long as they were still within limits. Problem I see is, they are both at 17mm thick now after turning so....scrap I guess.
I already ordered two new ones and will pick them up and install them this weekend. (along with a shite-ton of other little jobs I need to finish on Olive)
Lee _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
