1981 931 - Need replacement catalytic converter
canyonblaster
PostPosted: Tue May 01, 2018 8:59 am    Post subject: 1981 931 - Need replacement catalytic converter Reply with quote
Cross posting from part wanted section.
Appreciate any advice!
http://www.924board.org/viewtopic.php?t=43696
PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
Past P cars, 1985 944, 1987 951, 1990 911 C4, 2002 Boxster S, 2005 996 GT3, 2013 911 C2S
Daily Driver P cars: 2008 Cayenne GTS, 2013 Cayenne GTS
canyonblaster
PostPosted: Mon May 07, 2018 4:56 am    Post subject: Reply with quote
ZERO luck but I did find a hollowed out one available @ Parts Heaven.
Anyone have insight as to how the car will perform & sound with a hollow cat?
Thx
PostPosted: Mon May 07, 2018 10:09 pm    Post subject: Reply with quote
Should work well with a rodded-out cat... or check with Dan (ideola), I'd almost swear I gave him one years back, might still have it as a valid spare...
PostPosted: Tue May 08, 2018 4:29 am    Post subject: Reply with quote
Why bother with a Cat? Straight through pipe fwiw!
3forall
PostPosted: Tue May 08, 2018 6:21 am    Post subject: Reply with quote
I'd say replace it with a cheap resonator. Without the cat (straight) it gets too loud and the resonator helps the sound be a little less agricultural.
1981 924 Weissach edition
1982 931 - Megasquirt and liquid intercooler
1969 911
canyonblaster
PostPosted: Tue May 08, 2018 6:53 am    Post subject: Reply with quote
Thx guys. I don't want it too loud, I already have a rear muffler delete with a low restriction Ansa/Monza type twin tip. It actually sounds great currently (other than the rattle from this old cat).
I like the idea of less restriction but don't I need the replacement piece to have the connector for the bypass pipe the car has? I'm not very savvy about how to deal with this.
Thx!
PostPosted: Tue May 08, 2018 5:09 pm    Post subject: Reply with quote
You are best off without any restriction/mid box/cat between the turbo and back box. Change the back box size to tune the sound you are happy with. The turbo naturally reduces the note. The back bock reduces further with limited back pressure/restriction for better spool up.
canyonblaster
PostPosted: Thu May 10, 2018 1:05 pm    Post subject: Reply with quote
The car has to pass emissions every five years. Next test is in 2 years. Local emissions center mgr says it has to have a visible CAT. He also warned that although it only has a to pass an idle test (not a full roller test), w/o a CAT it may not pass....
I may have a line on a used OEM CAT with lower miles, and Parts Heaven in California has a hollowed out CAT for sale. Not sure what to do.
canyonblaster
PostPosted: Sun Jun 10, 2018 4:17 am    Post subject: Reply with quote
This is a bummer... In trying to chase down the annoying rattle noise coming from somewhere around the exhaust, my tech thought it was the CAT. Well, he removed my exhaust and gutted the cat, AND cut open the resonator just behind the CAT, removed the insulation and some kind of retaining ring that was broken anyway, and welded it all up and put it back on...
The rattle remains and is now louder! Ugh.
It my be anything. Possibly the turbo bearings?
THE WORST part is this, now the car won't spool up and build nearly as much boost. I have a gauge and it was making 10 psi @ 4-5K and now it struggles to get to 5-6 at ANY RPM.....
Is this from lack of back pressure? Now what am I going to do!?
PostPosted: Sun Jun 10, 2018 4:25 am    Post subject: Reply with quote
Could be the pop off valve in the compressor housing rattling and now leaking boost by badly?
I suppose a broken WG (waste gate)spring could cause these symptoms too but I'm not sure if that ever happens..
Post a video of the noise and other symptoms.
I don't think you would hear turbo bearings until you hear the wheels hitting the housings, and you would be smoking like crazy..
Is the turbo not spinning up or just not building pressure?
If the pop off valve is leaking and rattling it would spool like crazy and make little boost..
But, if the WG is leaking and rattling the turbo wouldn't spool for crap but still give whatever boost you get from the little spooling it will do..
Take your air compressor and dial it down to like 10-15psi..
Take the WG signal line off your upper charge tube and actuate your WG by blowing air pressure in that line.. You should hear a really creeky springing noise and it will slam back shut when you release the pressure..
If it doesn't do anything try it up to about 30psi but I wouldn't go any higher than that..
Do you pull 1st gear to redline at WOT atleast once every time you drive the car as the manual suggests?
80 Turbo - Slightly Modified
canyonblaster
PostPosted: Sun Jun 10, 2018 5:45 am    Post subject: Reply with quote
Thanks! I wish I could find one local tech who really understands this car....they all seem to chase their tail....
PostPosted: Mon Jun 11, 2018 12:13 am    Post subject: Reply with quote
The turbo recirc valve and it’s spring can rattle. Mines done this since it’s rebuild on and off. Will only do it on idle as there’s no boost to seat it.
A boost leak will reduce boost. Possibly a slightly gapped recirc valve
I burst wastegate membrane will overboost not underboost. A wastegate stuck open may cause under boost but would also cause the turbo to overspin
