bureau13
Joined: 07 Sep 2017 Posts: 495 Location: South Florida
Posted: Sat Oct 28, 2017 12:44 am Post subject: Aftermarket mufflers and boost gauge installs |
A couple questions....first, where do you guys plumb your boost gauges into? Is there a generally preferred place to do that? And is there an existing path through the firewall that I can get to easily (I'm mounting the gauge in the center speaker location).
Also, my car sounds like it has an exhaust leak. The tailpipe itself is missing, but I don't think that has much to do with the sound...I suspect the muffler has deteriorated. I don't mind the loud, but if there's an opportunity to replace it with something that might sound better as well as providing better flow, I'm all for it. I have a Borla on my 928 which sounds great, but I saw a video comparing a Borla and a Magnaflow on 4 cylinder VWs (recent though, like Golfs, which I realize sound very different) and the Magnaflow was amazing. Anyone do this? Any real benefit beyond sound?
Thanks _________________ 1982 931
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2007 Hummer H3 (Timing chain guide failure)
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen) |
Garagenut
Joined: 09 Jun 2019 Posts: 5 Location: Logan, ohio 43138
Posted: Fri Aug 23, 2019 7:15 am Post subject: |
I too am looking for a better and louder sound than the borla.... Did you get any info that you can share? _________________ Red '87 924s cherry (almost), love it! |
Joined: 29 Jul 2001 Posts: 9081 Location: Royal Oak, MI, USA
Posted: Fri Aug 23, 2019 9:25 pm Post subject: |
I've plumbed my boost gauge teed into one of the small ports by the throttle body (downstream of the throttle plate of course). There's a port in the firewall behind the cold start valve/intake, which I used. Had to put a short piece of brake line through there to carry the vac signal, otherwise a flexible hose would get pinched.
Haven't had capacity to change out my exhaust yet, but I plan to put a Dynomax on there when I have time... busy building an NA race motor at the moment... _________________ Vaughan Scott
