doolie72
Joined: 01 Dec 2018 Posts: 27 Location: California, USA
Posted: Mon Jan 27, 2020 3:39 pm Post subject: 1980 931 European vs US |
Can anyone clarify where the extra power comes from in a 1980 European spec 931? I’ve searched around and discovered that for 1980 the compression ratio was 7.5 for both euro and US, so assuming it might be down to one of all of the following:
Timing (for higher octane fuels)
Boost
Lack of catalytic converter?
Thanks |
bureau13
Joined: 07 Sep 2017 Posts: 495 Location: South Florida
Posted: Tue Jan 28, 2020 12:36 am Post subject: Re: 1980 931 European vs US |
My understanding is that the bulk of it is due to increased boost, but I don't know that they didn't make other changes at the same time. They may well have pulled some timing to make that increased boost safer?
| doolie72 wrote: | Can anyone clarify where the extra power comes from in a 1980 European spec 931? I’ve searched around and discovered that for 1980 the compression ratio was 7.5 for both euro and US, so assuming it might be down to one of all of the following:
Boost
Thanks |
_________________ 1982 931
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2007 Hummer H3 (Timing chain guide failure)
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen) |
Posted: Tue Jan 28, 2020 1:29 am Post subject: Re: 1980 931 European vs US |
| bureau13 wrote: | My understanding is that the bulk of it is due to increased boost, but I don't know that they didn't make other changes at the same time. They may well have pulled some timing to make that increased boost safer?
Boost
Thanks |
Incorrect. The boost is the same. It’s a combo of compression ratio, turbo and ignition differences. 7bhp on paper does not reflect on the road that it’s quicker. Just delivers power differently to series 1. Not one or the other is better or worse. Just different. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Tue Jan 28, 2020 2:15 am Post subject: |
Steve, i think you are mixing up the s1 s2 thread with this us vs row discussion
Its both boost and timing, and also the cat if course. So pretty easy to get it back up to row specifications _________________ 1980 924 Turbo
bureau13
Posted: Tue Jan 28, 2020 7:17 am Post subject: Re: 1980 931 European vs US |
Unless everything I've read about it is wrong, the Euro car made ~10 psi and the US version was closer to 6. That's a significant difference.
| Carrera RSR wrote: | | bureau13 wrote: | My understanding is that the bulk of it is due to increased boost, but I don't know that they didn't make other changes at the same time. They may well have pulled some timing to make that increased boost safer?
Boost
Thanks |
Incorrect. The boost is the same. It’s a combo of compression ratio, turbo and ignition differences. 7bhp on paper does not reflect on the road that it’s quicker. Just delivers power differently to series 1. Not one or the other is better or worse. Just different. |
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
Posted: Tue Jan 28, 2020 8:10 am Post subject: |
| Cédric wrote: | Steve, i think you are mixing up the s1 s2 thread with this us vs row discussion
Its both boost and timing, and also the cat if course. So pretty easy to get it back up to row specifications |
Yep. You are right. Travelling Germany and posting on the fly  _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Mike9311
Posted: Wed Mar 11, 2020 2:16 am Post subject: |
Sorry so late to this topic.... This I know for sure since I have one
1980 USA has the larger 2664 Compressor wheel and smaller 4.10 Turbine housing. (1981 and '82 USA received the 2660 with 4.10)
Pretty sure the Euro 1980 had the small 'old school design' 2470 Compressor and larger 6.10 turbine housing.
I know its been said its easy to find the 2664 here in USA but not so much anymore. It was only 1980. _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
