bureau13
Joined: 07 Sep 2017 Posts: 496 Location: South Florida
Posted: Sat Jul 04, 2020 3:45 am Post subject: Locked my keys in the car :-( |
So I was working on the AC, threw my keys on the floor with my tools, then later instinctively locked the car when I shut the door. Of course, I never bothered to get an extra key (only got one from the PO).
I have AAA, so yay, right? The locksmith couldn't get in the car. He tried a slim jim, and he tried wedging the door open to slip a bladder in between the door and frame, but couldn't get it open far enough to get the bladder in there.
What's the best way to do this, surely I'm not the first idiot to encounter this problem  _________________ 1982 931
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2007 Hummer H3 (Timing chain guide failure)
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen) |
dogleg5
Joined: 01 Apr 2020 Posts: 29 Location: No longer with us
Posted: Sat Jul 04, 2020 10:40 am Post subject: |
| Don't think you have a lot of options. Take the vin to a porsche dealer and have a key made? Not sure that can be done on an older car. Find replacement glass from a "yard" and break whatever window you have a replacement for? Or, what I'd try, take the key for the 928 and slide it in and out while trying to turn it at the same time. Also insert the key and lightly tap it with a hammer while trying to turn it. None of that will probably work but...worth a try. |
Posted: Sat Jul 04, 2020 10:56 am Post subject: |
Wonder if the rear quarter windows can be popped out from the outside of the car....
https://www.youtube.com/watch?v=dE2Q6WayLpY _________________ White 87 924S "Ghost"
bureau13
Posted: Sat Jul 04, 2020 12:50 pm Post subject: |
That is my current plan of action. It looks pretty easy in the video, but I'm having a bit more trouble. Partly my seal is old and need replacing (opportunity!) and partly I'm paranoid about breaking something, but it does seem doable.
As for the 928 key, it's not remotely similar to the 924 key. Significantly bigger, I don't think it would fit the lock at all.
OK this is funny, I was just thinking to myself if only I had taken a picture of the key I could send it off to keysforclassics, and then I remembered...I did! I even found the picture. So that is a perfect solution, except for the wait. So I'm going to do that, but I'm still popping that window out (I hope) since I've partially butchered the seal already anyway.
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
Posted: Sat Jul 04, 2020 9:24 pm Post subject: |
Plastic packing band, folded in half creating a loop, prise the top of the door open with a screwdriver wrapped in a rag, slide the band into the top of the door opening and slide it down the to lock pin on top of the door trim, loop the banding around the head of the lock pin and give it a sharp pull, voila! door is open and no damage.........simples _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Sat Jul 04, 2020 9:26 pm Post subject: |
Can also try a wire coat hanger but that will scratch the paint on the door and jamb _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Sat Jul 04, 2020 11:50 pm Post subject: |
I just locked myself out of my E36 the other day and ended up exploding my drivers door window in my face trying to pry a gap open to reach my keys..
Boom! she went and I was bleeding from like 20 little cuts on my arms and face, lol..
Luckily I had another window sitting and threw it in, but what a mess!!
Think it happened because I didn't have my battery terminals tightened from borrowing its battery all the time.. Made the locks freak out.. And ofcourse my spare key was in the glovebox too, because I'm kindof in the middle of moving..
I like the rear quarter window idea too for the 924, and you can probably get a used one quite reasonably from someone parting a car if you end up accidentally breaking it.. I kinda doubt they are in super high demand.. _________________ 80 Turbo - Slightly Modified |
Posted: Sun Jul 05, 2020 12:18 am Post subject: |
| Paul wrote: | | Wonder if the rear quarter windows can be popped out from the outside of the car.... |
Yes, I did it in the past for the same reason. _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
bureau13
Posted: Sun Jul 05, 2020 6:16 am Post subject: |
Update! Got the rear quarter out. Slightly butchered the seal, more because it's old and deteriorating than any other reason. I used the "string method" to get it back in, which worked pretty well, only I'm not sure if there's a trick to getting the metal insert for the seal back in? I wasn't having much luck there so I've left it off for now. If anyone has a tip for that, please share. _________________ 1982 931
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
Posted: Sun Jul 05, 2020 6:35 pm Post subject: |
metal trim needs to go into the rubber seal before you insert the seal back into the shell _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
bureau13
Posted: Mon Jul 06, 2020 12:58 am Post subject: |
Dammit. I was afraid of that. Well, I need to order a replacement anyway, and I have some slightly less crappy rear speakers I've been meaning to install, so I'll make a project of that soon.
| Carrera RSR wrote: | | metal trim needs to go into the rubber seal before you insert the seal back into the shell |
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
Posted: Mon Jul 06, 2020 9:11 pm Post subject: |
Porsche has only 4 diffrent keys for the 924.Get some Friends to Exchange keys…..
Also you can remove the small plastic cover from the door handle take the screw out,remove handle far enough to reach the unlock mechanism.
nobbi _________________ NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew..Plus : DEUTZ 4005 tractor Built 1967 |
madmardigan
Posted: Tue Jul 14, 2020 9:07 am Post subject: Did you get in? |
Did you end up getting in? That's the absolute worst. Nothing worse than looking inside your locked car to see your keys sitting on the seat or inside the cup holder  _________________ https://www.elpasotileinstallation.com |
DZGunner
Joined: 18 Nov 2014 Posts: 191 Location: Great white north
Posted: Wed Jul 15, 2020 11:51 am Post subject: |
I locked myself out of my car when I drove something like 200 miles to go test drive a boxter. I ended up using a coat hangar to pull the unlock latch up from the outside, going through the lower window seal on the door, and made it home as though it never happened  _________________ 1979 924 (Daily driver EFI)
1979 924 Sebring
1977 924
1977 924 (Parts) |
