DootToot
Posted: Sun Jul 26, 2020 10:48 am Post subject: Grounding Points / Intake Manifold |
Hey all,
My 82' 931 has the copper braided strap going from the negative battery terminal, onto the body, and then to the top of the intake manifold on one of the two protruding mounting points.
I was interested to see online that this is not usually where the car is grounded, and also that some 931's even have a different intake manifold.
I was wondering where the usual grounding point is, I havent seen an obvious spot down on the bell housing, but I'm expecting it to be somewhere down there.
I am also now curious what those two mounting points on the top of the intake manifold are actually for. I dont think I've seen a picture with them actually being used.
Posted: Sun Jul 26, 2020 11:17 am Post subject: |
I think that ground is mostly for the overboost switch on the upper charge tube, so the overboost switch has something to ground to.. _________________ 80 Turbo - Slightly Modified |
Harm
Posted: Sun Jul 26, 2020 9:03 pm Post subject: Re: Grounding Points / Intake Manifold |
Edit
Harm
Posted: Sun Jul 26, 2020 9:04 pm Post subject: Re: Grounding Points / Intake Manifold |
Please add .jpg and we'll see more.
| DootToot wrote: | | [img]https://imgur.com/QcvnU2p[/img] |
| Code: | | [img]https://i.imgur.com/QcvnU2p[color=darkred].jpg[/color][/img] |
| DootToot wrote: | | [img]https://imgur.com/4r2wK8c[/img] |
| Code: | | [img]https://imgur.com/4r2wK8c.jpg[/img] |
I would think it holds the gas-kabel support bracket (LHD) in that place on the S2 Turbo LHD engines.
One could use the bolds either side of the Coil to support a ground strap between the engine.
Kind regards,
Harm. |
Posted: Sun Jul 26, 2020 10:42 pm Post subject: |
Oh.. Yeah I didn't see the pics..
Those mounting points that you have the ground strap on are supposed to be for the throttle cable bracket like Harm said..
The ground strap for the intake goes somewhere on this bracket here circled in green.. To give the upper charge tube a good ground..
Atleast on my S1.. _________________ 80 Turbo - Slightly Modified |
DootToot
Posted: Mon Jul 27, 2020 10:46 am Post subject: |
Thanks for the replies (and technical support, sorry about the images )
In terms of grounding straight from the battery, Ill have a look at putting it near the coil like Harm said. Is this the usual point? |
Posted: Mon Jul 27, 2020 8:45 pm Post subject: |
From the coil mount, yes, to the rearmost intake bolt.
The charge tube should ground by that bracket directly to the main body of the intake. At least on the cars I've seen. _________________ Vaughan Scott
