Please help me figure out this broken bolt
gml
PostPosted: Mon Feb 07, 2022 6:07 am    Post subject: Please help me figure out this broken bolt Reply with quote
Picture: https://imgur.com/a/xcfLmuD
The bolt on the rear trailing arm broke off when removing the drum brake backing plate. I drilled this out and tried using an EZ out (bolt extractor) but I haven’t been able to get it out yet. I used a tap handle to screw the EZ out but the chuck of the tap handle broke instead.
It is drilled out a little bit off center so I’m worried if i use a larger drill bit I will destroy the threads, and if I need to remake threads with a helicoil the hole won’t be centered properly.
What would you do in this situation?
George
1982 924 NA 5-speed
Riggard
PostPosted: Tue Feb 08, 2022 6:30 am    Post subject: Reply with quote
I'd use a Dremel with a metal burr and see if you can reduce the hole of the old bolt a bit further, so that basically only the threads remain. After that remove the remaining piece with a small iron pick.
Alternatively you could also try torching the remainder red hot, it may come loose.
safe
PostPosted: Tue Feb 08, 2022 8:48 pm    Post subject: Reply with quote
You seam to have drilled the hole pretty centered and big. You may be able to pick the threads or knock them out with a sharp punch.
A tap might be able to grab and turn the remains out the right way.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
ChrisMadge
PostPosted: Tue Feb 08, 2022 10:33 pm    Post subject: Reply with quote
It needs to be perfectly centered, which is easier said than done.
In the past i have used a set of needle/round files to carefully enlarge an off center hole to the point where you can pick out the remaining threads with a pick and run a tap through. Time consuming but it works.
1984 MY 924 2.0 NA
1975 MG Midget
