Karlio
Posted: Wed Feb 28, 2024 2:42 am Post subject: Torque tube |
Apart from Black Sea R&D who does replacement torque tube bearings for 924 n/a?
And if you were to build a new torque tube out of aluminium tube what thickness wall would be recommended?
Cheers karl |
Posted: Wed Feb 28, 2024 3:22 am Post subject: |
Bearings are standard size as far as i know and i’ve heard of people using off the shelf bearings in their rebuilds.
The parts that are tricky to find are the plastic bushings that go in the centers of the bearings and rest on the torque shaft.
These you could find made by a Slovenian guy some years ago but i havent seen him around lately.
I have the drawings for these so i may try to make some.
The truly tricky bits are the outer ruber bushings that go on the outside of the bearings and rest on the inside surface of the torque tube.
If i’m not mistaken these are called vibration dampers and people re-use them or if they are dead they take them from other TTs and make a good set. _________________ Supercharger and EFI kits
Karlio
Posted: Wed Feb 28, 2024 5:04 am Post subject: |
| Have a shuftie at www.blackseard.com for the uprated bearings, they come complete. |
Karlio
Posted: Wed Feb 28, 2024 6:56 am Post subject: |
Really cool stuff! _________________ Supercharger and EFI kits
safe
Posted: Wed Feb 28, 2024 10:58 pm Post subject: |
I bought bearings and carriers from a Danish guy on Facebook. He sold the bearings or complete replacement torque tubes. I think it was info@9werk.dk, he doesn't seem to have any products on his website anymore. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
Karlio
Posted: Fri Mar 01, 2024 8:17 am Post subject: |
| Any thoughts on wall thickness for aluminium tube swap? |
ChrisMadge
Posted: Fri Mar 01, 2024 6:19 pm Post subject: |
| morghen wrote: | Bearings are standard size as far as i know and i’ve heard of people using off the shelf bearings in their rebuilds.
If i’m not mistaken these are called vibration dampers and people re-use them or if they are dead they take them from other TTs and make a good set. |
In the UK https://www.augmentautomotive.co.uk/ repair torque tubes. They also remanufactured the plastic bushing in aluminium for my torque tube. _________________ 1984 MY 924 2.0 NA
1975 MG Midget |
safe
Posted: Fri Mar 01, 2024 7:03 pm Post subject: |
| Karlio wrote: | | Any thoughts on wall thickness for aluminium tube swap? |
A tube of that size is pretty stiff. I would make an educated guess that an aluminum tube of the same thickness as the steel one would do fine.
There is probably some online-calculator where you can figure out torsional stiffness in a pipe in different materials and find a thickness where you have a sweet spot and correlate that to an of the shelf size.
Porsche had problems with the original steel ones in the 968 when it wasn't a fully welded tube, but split design. That would be a significantly weaker design. I think that has been the only issues of the stock one. Apart from the 924NA having a small and weak shaft.
Porsche also made an aluminum one for racing, no idea how think that was. They have been made after that, a guy here in Sweden had 2 made for a time attack car, but both are sold. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
At least 6mm i'd say, 8-10 sounds good to me...especially if you intend to run rigid engine/gearbox mounts. _________________ Supercharger and EFI kits
daniel
Posted: Sat Mar 02, 2024 10:12 am Post subject: |
Carrera's had a alloy tube if I remember correctly. See if you can find any specs. _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
peterld
Joined: 10 Dec 2006 Posts: 984 Location: Noosa Heads QLD Australia
Posted: Sun Mar 03, 2024 11:21 pm Post subject: |
IIRC, Mike9331 here on the Board made an alloy torque tube. _________________ 80/81 932/8 ROW |
jacobroufa
Joined: 18 Nov 2016 Posts: 542 Location: Belvidere, IL
Posted: Thu Apr 25, 2024 6:04 am Post subject: |
Mike did make one and last I knew it was fitted to one of his 931s.. It was quite a process; maybe he can chime in with the latest updates! _________________ 1980 Porsche 931
1981 Porsche 924 Weissach |
chuck21401
Joined: 20 Feb 2005 Posts: 611 Location: Annapolis, MD
Posted: Thu May 02, 2024 4:19 am Post subject: |
Thanks for the link. Quite a process.  _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler |
Mike9311
Posted: Fri Jun 28, 2024 11:42 pm Post subject: |
Hi Everyone
Apologies for being such a terd and not being around here. Life has just really been busy and it kills me just to come check things out here when I am not getting my hands dirty myself. Well they do get dirty just not on a 924 (getting started again on the heads stuff too)
I need to get the exact specs for this but Morghen's 6mm is about right
Originally posted here in this thread. This is for the S2 81+ Audi Trans but I am working on a S1 version that is roughly half done already. With the right shafts the tubes would work for NA set ups as well. This car is actually getting worked on right now Hope to make more progress today and get it off the lift shortly
https://www.924board.org/viewtopic.php?t=42087&postdays=0&postorder=asc&start=45
As you scroll down through the pics I'll make some more comments. I am sure I'll miss something along the way but I'll post more
You need a secondary tube welded in this flange after boring out the steel portion. This is not the actually tube section here but a step to help match up to the flange
Now I have developed new rebuildable bearing carriers. In this way I could control my fitment by controlling the durometer of the rubber used and in some ways hoped to increase the stiffness of the system. The bearings are the more commonly available C3 internal clearance rather than the C5 looser internal clearance tolerance originally spec'd. I have lots of thinking as to why things were done and spec'd the way they were on the original parts. For one thing the original torque tubes lined up in a lathe between centers are never straight. This could be why they used sheetmetal based carriers that could deform a bit to adjust to any irregularities. My carriers are also designed to adjust slightly but internally rather than by the body flexing. It does appear that you could use stock carriers in the Al tube as well. I also do not believe in larger bearings. These bearings need to spin up cold and additional inertia isn't helpful. Why plow larger balls through cold grease? Plus the weight? They are just there to keep the shaft straight.
Internally they don't look like this anymore. These are just old prototype pics
The S1 tube is ready as well as the engine side flange. Just working on the final version of the trans side flange.
 _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
