TDC
Nzl924
PostPosted: Mon Jan 20, 2025 8:31 am    Post subject: TDC Reply with quote
Hi,
Trying to fit a new cambelt to my 924 (engine is out and belt was off when I got the enginet) and want to confirm the cam and crank are correctly positioned at TDC. If I line the crank to the mark on the pulley, what is the best way to determine if the cam is at TDC?
Thanks
copeina
PostPosted: Tue Jan 21, 2025 12:54 am    Post subject: Reply with quote
There is a similar mark on the cam as well. When both are on their marks, things are where they should be.
Hope that helps,
/K
1978 924 NA Project
PostPosted: Tue Jan 21, 2025 2:57 am    Post subject: Reply with quote
Note that the mark on the cam gear is on the back (windshield) side of it.
fiskolja
PostPosted: Wed Jan 22, 2025 1:42 am    Post subject: Reply with quote
Is it possible for the mark on the cam gear to be out of sync, as in the gear having rotated independently of the camshaft?
Is there any way to verify that the gear is in sync with the shaft?
924 NA 1977
scm924s
PostPosted: Wed Jan 22, 2025 2:45 am    Post subject: Reply with quote
cam pulley is on locating key, can't be misaligned. You need to get No1 cylinder at top dead centre on compression stroke and TDC on the flywheel
Follow the setting up on here:-
https://members.tripod.com/darrin_smith/porsche/924cam.html
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
fiskolja
PostPosted: Wed Jan 22, 2025 4:29 am    Post subject: Reply with quote
Ah thanks!
I decided, for some reason, to adjust the camgear itself for it to line up after waterpump replacement and it felt like it slipped from the shaft. But I haven't had problems since so that explains why
924 NA 1977
