Headlights - Won't go down
Nzl924
PostPosted: Sun Aug 10, 2025 4:49 pm    Post subject: Headlights - Won't go down Reply with quote
Hi All,
I've looked around the forum and couldn't find anything exactly as my issue. My headlights are going up but won't go down.
I have checked Clarks Garage and tested the power going to the 4-pin connector. All looks good except the green wire, it is reading ~11V while the other (blue?) reads ~12.6V when the lights are off. From Clarks Garage they should both read 12V when the lights are off.
So, if I short the green and blue together, the lights go down!
Is this likely to be an issue with the switch, poor connection somewhere? Does anyone know how to test the switch.
Thanks
Stu
Nzl924
PostPosted: Sun Aug 10, 2025 5:24 pm    Post subject: Reply with quote
Tested resistance between pin 57k (which I think goes to the green wire on the headlight motor) and X when the switch is in the off position and it is reading ~0 Ohms, so I guess the switch is ok?
1981 Porsche 924 NA
(Last on the road 2011)
PostPosted: Sun Aug 10, 2025 10:29 pm    Post subject: Reply with quote
Give them a tap with the palm, perhaps there is a mechanical issue that the motor cant overcome.
chuck21401
PostPosted: Mon Aug 11, 2025 3:38 am    Post subject: Reply with quote
Check the plastic cover that surrounds the headlights. Sometimes that can come loose and prevent the lights from moving freely. And in that case the motor can burn out or worse. Even after you turn off the ignition, the motor could still be trying to retract the lights.
Nzl924
PostPosted: Mon Aug 11, 2025 7:00 am    Post subject: Reply with quote
Thanks for the replies, I don't think it is a mechanical issue as if I supply 12V to the green pin the lights go down as you would expect.
1981 Porsche 924 NA
