takafoomi
Joined: 12 Jun 2026 Posts: 1 Location: Victoria, Minnesota, USA
Posted: Fri Jun 19, 2026 9:02 am Post subject: 1981 Turbo Ignition Coil Question |
Hello! My 1981 Turbo ignition coil shows a primary reading of 3.5 ohms and a secondary reading of 7.46 .. Now, this is not the original Bosch coil and I realize it is out of spec for 1981. However, can you put a modern coil in it and have similar readings and the car will start/run fine? Or do I need to find a coil which is closer to the 1981 spec.
Thanks! |
