Johann
Posted: Wed Aug 10, 2016 7:55 am Post subject: Why does the 931 have a different Auxiliary air valve? |
The 931 has this auxiliary air regulator:
Bosch part number: 0280140220
Porsche Part number: 931 606 102 00
The Normally aspirated 924 has this auxiliary air regulator:
Bosch part number: 0280140169
Porsche part number: 047 133 453 A
Can anyone tell me what the difference between these valves are since the NA version is way cheaper than the 931 version. Are they interchangeable?
Posted: Wed Aug 10, 2016 10:53 am Post subject: |
Is the turbo unit stronger in some way because it's exposed to boost pressure? _________________ Toofah King Bad
Posted: Wed Aug 10, 2016 11:11 am Post subject: |
The turbo unit is much larger, has larger orifices, and is not adjustable in the manner that the NA is. As for internals, I don't know what the difference might be. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Aug 10, 2016 12:19 pm Post subject: |
You also might start cross referencing other euro cars. That type of aav was installed on literally millions of cars. _________________ Toofah King Bad
Johann
Posted: Wed Aug 10, 2016 4:00 pm Post subject: |
| Knowing Porsche there would have been a good reason for it. As far as I know the 931 and 930 share the same valve, so Rasta Monsta, I think you might be correct in that it is very likely that they are beefier to deal with the added pressure in the inlet circuit. |
Johann
Posted: Wed Aug 10, 2016 7:14 pm Post subject: |
Still scouring the web for answers, but I came across this photo. The refulators seem to be the same size.
